- 27 Dec 2008
Hello,
I'm going to be getting a 750D this week with a new cooler. I was going to get a H110 then I saw this.
YOUR BASKET
1 x OcUK Tech Labs - Corsair Obsidian 750D Windowed - 750 EX360 Watercooled Case £270
1 x Intel Bracket Fitted £0
1 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99
Total : £287.59 (includes shipping : £10.50).
First question is this just complete overkill for just a CPU as I have no intention of water blocking my GPU?
Second would I be able to fit a optical drive with the pump/reservoir there? If not that is a deal breaker.
Thirdly the H110, should I buy after market fans for it and if so what ones? (I do have a couple of these spare).
YOUR BASKET
1 x Akasa AK-FN062 Apache Black Super Silent 140mm Fan - 4 Pin PWM £14.99
Total : £18.90 (includes shipping : £3.26).
Fourthly Same question for the stock 750D case fans.
Goals. I really want it as quiet and cool as possible. I know I will have to sacrifice one of the other. A good balance will hopefully be the result.
Budget: none.
Any other input welcome
YOUR BASKET
YOUR BASKET
Budget: none.
