Hi all,
I currently have a sapphire HD7750 overclocked in my HP8000 elite machine that hosts a few websites and some other bits.
It is used occasionally for LAN gaming if a friend or guest comes over.
I've just seen these:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-058-KF
And drooled a little! It seems very nice for a low profile card.
Knowing that the 7750 draws 55w from the 75 available in the PCI slot and my computer still seems to take it I wonder if the 750 will be ok? From doing some research it seems it should draw a similar amount, although of course is limited by the 75w PCI allowance anyhow.
I've contacted overclockers and I am hoping they will come back into stock.
I've also been looking at trying to upgrade the PSU as it is on the limit at the moment although seems to be coping well, but options are limited.
The machine does only run an e8500, two usb devices and two sata drives, thoughts?
Cheers!
Cheers!
