750ti or r7 370
10 Nov 2011
Telford
Looking for a gpu to go in my htpc / steam machine.
Only after high settings not bothered about ultra.
Will be on a 1080p 42" tv
Budget is around £130
So far debating
Evga gtx 750ti sc
Msi r7 370
Or upping the budget a bit if there is a big enough increase and
R9 380
Gtx 960
Which is going to give me 40+ constant fps at high settings.
Go for the 380 or the 960, they're both quite close to maxing out details at 60 fps for all but the latest games or the most demanding mods.
The 380 is slightly faster but it's less power efficient so if that isn't a concern, that's what I'd get it.
Edit: I've noticed the context, a steam machine, in which case the cooler, more efficient 960 may actually be a better choice.
yes but its slightly more expensive as well.
750 ti< 370<960<380
750ti = £97
370 = £125
960 = £160
380 = £150
which will give best bang for buck?
ti would be the best bang at 97 but as suggested you might want to see what the 950 performance and price is like.
