750ti - still worth it?
25 Oct 2013
Tipton
Hi
I currently have this pc which i built
http://forums.overclockers.co.uk/showthread.php?t=18669221
So not too shabby, but have no graphic card..
It is currently used as a media storw which i am thinking is a bit overkill and have tons of games in my steam account, so why not use them?
I want something low powered because of it being on while i am watching films/streaming/itunes server etc
I do not have interest in playing things at ultra, but would like to play some games without it looking naff or stuttering
I know the 750ti is low powered but is it still a worth while purchase still?
I'm playing in 4K on a GTX 760 so it's definitely doable. If you can I'd stretch to a newer model though - I have one because I already own one, I wouldn't be buying one.
You have enough posts for the MM so why not pick up a 970 second hand? They're going for £180, which isn't miles over your budget but would be far better bang for buck at 1080p.
Running a GTX 750 Ti coupled with a Xeon E3 1230 V3 works very well with Windows 10 and most upto date kernel Linux Distro's.
I have found it plays WoT, WoWs, War Thunder, KSP at acceptable FPS. As it is the EVGA SC it does not require a serperate PCI-E 6 pin.
Does what is needed at a very low power draw.
