7600gt flickering screen
5 May 2003
Just installed one of these cards in my new build. The screen now flickers every so often. Doesnt stay still for more than a minute. Its a slight flicker , doesnt shake or anything. I guess like a loose connection. I have double checked all wires and everything is sound. The monitor is fine as I only just moved it from the old pc.
I am thinking it might be time for a newer monitor. The current one is approx 4 years old and only has a 60 refresh rate.
Is this likely to be the problem? Or could it be the card?
I had the same problem with my 7900GTX 'EE's, turnt out to be just a driver problem.
ok, it didnt flicker with my old card which was a 6800LE.
I have noticed it also flickers on boot up and when I enter bios. Now am I right thinking that the drivers are not loaded at that time?
I tried a lower resolution of 1200X800 with a 75 refresh, still flickers.
Is it still likely to be a monitor problem?
Also I installed the latest beta drivers and its the same.
Might try to dig out an older driver or install the one from the cd I got with the card.
