Hello again, need to consult your (usually) wise selves.
Just re-installed windows and oh my god its better, much faster games load up instantly... its great.
Decided to wait with really overclocking my leadtek a7600gt till after the re-install and till i had some case fans (previously had a single 80mm rear) I now have the 80mm rear (out), 80mm front (in) and the 120mm side (out). The 120mm really puts out some air and despite being a bit noisey is doing the job alright. If it helps its situated almost directly opposite the cpu.
However, come to overclock the graphics card and its gone from 560/700 to 635/800 but now idles at around 56 degrees and max's out at 68 degrees during far cry. No artifacts and its been running fine... however i'm reluctant to continue with the core with temperatures increasing like thay are. Is 68 degrees too high or acceptable?
What should i look at in terms of cooling? The obvious easiest ways would be drill another hole in the side and whack either an 80mm or another stonking great 120mm in as an intake fan near the graphics card. I also looked at the PCI based exhaust fans but havn't really seen them in action or head of them being used so i was unsure about it.
Alternatively i guess i could fit an aftermarket cooler, but if another intake fan would yield better results i would much prefer to do that as fitting a new coller will invalidate my warranty and the card is only 2 weeks old.
Funny, it was running alright otherwise, far cry, steam games and need for speed most wanted were all playing artifact free.
