7600GT vs 7900GS
3 Dec 2006
7600GT (£90 inc vat):
Specification:
Product - Inno3D Geforce 7600 GT
Chipset Geforce - 7600 GT
Memory - 256MB GDDR3
Core Frequency - 560MHz
Memory Frequency - 1400MHz
RAMDAC - 400MHZ
Interface - PCI-Express
Pixel Per Clock - 12
Memory Bus - 128-bit
Max. Resolution - 2560 x 1600
SLI Ready - Yes
Output - Dual-Link DVI, TVO
7900GS (£117 inc vat)
- GeForce 7900 GS core running at 450MHz
- 256MB GDDR3 Memory running at 1320MHz
- 20 Pixel Pipelines
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- SLI ready – Upto 2x the performance of a single GPU
- True High Dynamic Range Rendering Support – Based on Open EXR technology
From what I can tell, the 7600GT is better. I'm on a budget so obviously I'm looking for the best deal, but even so, the cheaper one actually looks better here? Am I missing something?
got the pallit 7900gs and my bro has the geforce 7600gt,mine is better in everything we compard them with,benchmarks and games.
the 7900gs is a good buy and definitely worth the extra cash.
dave
:D :D :D :D
Comparing my old GT's 3dmark scores with 7900GSs I've seen, it doesn't lose out by much at all in the SM2.0 tests, but it gets its head handed to it in SM3.0/HDR.
7600GT = 128-bit Memory Interface
7900GS = 256-bit Memory Interface
If your budget allows for the extra £27 then defo get the 7900GS!
Whilst the 7600GT is a decent bang for buck card, the 7900GS is *up to* twice as fast when gaming at 1280x1024 res with 4xAA + 8AF, great overclockers as well.
/I'll leave it to others to try talk you into buying a X1950 Pro instead (which is a tad faster, but a tad dearer).
