- 22 May 2007
Thinking of upgrading my cards and was looking at the 640MB 8800GTS. I currently get 12401 in 3Dmark05 with my 2 x 7600GT XXX's. What 3Dmark05 scores are people getting with 640MB 8800GTS's?
Dravic said:I get about 18k in 05 and 11.5k in 06 with a 640Mb GTS.
MeatLoaf said:I get 17.2k in 05![]()
320Mb version
Would be ideal for that res!samzetec-s said:^^ Nice might get 320MB actually as ive only got a 19" TFT.
gt_junkie said:Would be ideal for that res!![]()
Nothing can touch them in terms of price/performance!
gt
Raves said:So, if you are thinking of playing CoH, or perhaps readying yourself for a furture title - you may wish to consider getting a 640MB version.
Either that, or prepare to turn your texture settings down to accomodate the 320MB frame buffer.
Raves said:I have a 8800GTS 320MB that I received as an RMA replacement for my 7900GTO 512MB that went ****-up.
While the 8800GTS 320MB out scores the 7900GTO 512MB in 3dMark, its performance in Company of Heroes at maximum possible settings is much worse.
I think this is because of the smaller frame buffer.
MeatLoaf said:Company of heroes runs fine maxxed out here![]()
Well, when playing oblivion and stalker with max settings at 1280x1024 the video memory usage is often 550Mb+. I'd definitely go for the 640Mb GTS if you want to future proof a bit more.samzetec-s said:Does the extra 320MB make the difference? Im looking to play games maxxed and future ones for a while.
I think so too. Another member on these forums saw a graphics bottleneck when using a single 8800GTS 320mb with a low end CPU, it couldn't keep up.Cyber-Mav said:seems like the lower end cards are more efficient in multi card setups. then again it could be cpu limitation....
