If you want a perforamce card for £400 or under get Zotac check the benchmarks epic card
I have just had an RMA with Asus, which took 6 weeks. I would stick with Gigabyte and EVGA and even MSI for a quicker turnaround if you do run into issues. The best warranty cover is the best idea.
as above, there isn't much to choose between them unless you're spending money on Classified or ASUS DC2. EVGA are great for warranty (especially under water) but as they bin there cards, you're more likely to get a lower clocker.
People tend to be getting very good air clocks with Gigabyte ref cards, so that's where I'd put my money if you're staying with air cooling.
I am not native english...
.1200 is monkey clocks on a Ti..
Anyway, as I said in my next post. I'd go with EVGA / Gigabyte for warranty reasons alone![]()
When you have the central heating on in cold weather it does not take long to hit the 60% RPM in my home as ambient air temps make a huge difference to me but I only have decent air cooling in my case on the CPU. I played around with the fan profile on both the std 780 & 780Ti it starts to get quite loud around 60% RPM.The WF3 is fairly audiable at 60% though nothing extreme but I have no idea what you'd have to do to make it get that high other than turning it up manually - even under torture tests the fans on mine don't exceed 38% IIRC.
Another thing which makes a huge difference is the type of AA settings you apply. FXAA seems to have the lowest FPS hit if I tried max x16/32 AA levels it would really heat the GPU up quickly in some games which are shader FX heavy.
Crysis 3 for instance as soon as you start the game its using all the shaders so ramps up the RPM. Its a shame you cannot control or disable GPU Boost 2.0 I suspect that is the culprit it seems to enable itself in some games more than others which could be why the fan RPM increases.
Thanks but think I will wait for Nvidia to offer a driver solution to this its only certain games like Crysis 3 & or if air temps are high due to central heating being on. GPU Boost 2.0 can help sometimes if your FPS are going just below your vsync.If your cards are throttling heavily, use the Skyn3t BIOS. One of many that disable boost.
1200 is a good overclock but it's not exactly great in terms of what a lot of reference cards can do.
Just using logic as I'm pretty sure your silicon all comes from the same pot so it's only fair to assume you're going to get less reference cards doing decent overclocks. Although I have three reference SC cards on water, one of which that does 1316.
On shader heavy games like Crysis 3 it goes too far & boost's too much!
