- 30 Nov 2016
Just did my first de-lid, and for those who are thinking about it thought I'd give my experience.
Firstly, it was very easy. Trickiest part is the application of the liquid metal. It comes out quickly so worth doing a few tests with the siringe so you know how it flows. Nothing, nothing, everywhere is a good summary. Other than that took about 45 mins end to end.
In terms of performance, I was running 4.8 Ghz and 1.23 v. Prime95, large FTT i would get to 80-87. I'm now running 5.1 Ghz at 1.33 v. With the same settings highest it gets to is 71 degrees. In terms of stability i've done an hour of realbench but time will tell.
All in all, really pleased. It really is like a different CPU. May go for 5.2 as seems I could do it but happy with less fan noise.
