775 air cooler
22 Nov 2010
Hey..! Anyone recommend best value air cooler (mount and fan) at around £30?
I'm going to be running a q9500 on a Asus P5P43TD PRO Motherboard. Wont to overclock as much as possible without really going over budget. I have been browsing the online store but there are so many!! Which to choose!! Arrgghh! Anyways, all help is much appreciated, Thanks..!
I got the Akasa Venom (a bit more than £30) for my Q9400, it's now stable at 3.6 and doesn't go over 61C on load with IBT/Prime. Going to stick another Viper on it for push/pull in a couple of days, so should shave off another 1 - 3 deg.
Depending on your preference, cooling performance vs. noise levels, relative to value for money, you should be looking at the aforementioned Gelid Tranquillo or the Cooler Master Hyper 212 Plus.
The Tranquillo is exceptionally quiet and offers good quality cooling, well worth the extra ~£6 in my opinion.
