Im getting ready to buy the 24-70 F2.8 Nikon lens for my D300s, its pretty much the perfect range for most of my shots, i checked all of my best pictures and most hovered around 40mm. When the D700 replacement comes out ill bag that so then it will be perfect.
Anyway, im trying to figure out circular filters, and getting confused. it doesnt help that googling for the B+W tech codes doesnt bring up any image examples either... for example B+W 486M UV/IR.
I want the following and dont mind paying upto £200 per filter if I need to spend that to get good results (which is some of the advice i have had).
Polariser
UV filter
Protector
ND's
Grad ND's for landscapes
UV
Currently i just use protectors but 72mm ones i think. I also have a hoya UV filter which doesnt seem to make any difference to my shots, so its probably cheap and lost its coating.
The other option is a Lee filter setup but im told its a pain to change filters and because its so modular is just a pain to work with all things compared.
Finally if you have them can you post up some image samples you have taken with different filters and explain what filter you used ? Thanks.
Polariser
UV filter
Protector
ND's
UV
