780 Lightning overclocks
I am using the latest version of AB and working fine for me on over volting. Are you sure you are doing everything correctly? Maybe PM Nick and ask him what he did.
Yep run the rbby tool as admin for the first time, the core is good but as you know and been said the mems are not so good, msi let the card down big time using elphida which is a shame as there fantastically built cards. Just stay away from heaven and valley bench's!!!
Tips??
Tune your ram, run as high a bclk as your card will allow, use cinebench for stability test then add 2 more clicks of vcore.
Set to best performance
End all processes that are not needed
If your on 1440 monitor set it too 1080p
Use 320.18 drivers
And most of all keep it cool!!!!
And most of my good scores are done with a fresh-ish install,
Once you have a good score at the limit, note down settings, turn pc off let it cool down for 20 mins, back on try upping a notch or 2 (5-10hz) and try, your first run will generally be the best.
I've just tried pushing the CPU a little more as I know what I'm doing there a little better... I reckon I've got 4.9 pretty solid on that but now I'm getting an error code on the RAM which is no doubt holding it back. I can run 1600 11-11-11-28 at 1866 9-9-9-24 but the increase in any benches is negligible...
I assumed the 'enable +200mV' meant it's enable a max of 200... that's not the case then :D
I did consider making a few ice cubes out of de-ionized water and drop one in the res but max I've seen today on the GPU is 36ºC
