7800 Temp ?? Help
28 Jan 2007
Hi all
I have Sli Gforce 7800 GTX the temp on a hard full load has reached 80 Deg
Is this really bad. ? (About 42 idle)
Ive replaced Standard Heat sink with zalman ones but no change.
I also put a high speed fan blowing on it and it dropped to about 72 but the noise was too much for my poor ears.
Anyway any advise would be great
Thanks in advance
My BGF 7800GT, which is heavily overclocked, sits at 50c idle and goes up to between 60 and 80 depending on the game.
They are fine all the way up to 115c, though I would start to worry a little at about 100!
Your temps are fine :)
Thanks a lot m8
it was making me worry a little .. i think its the bottom card making top card a little more hot.. and i have no room for a pci exhaust fan :(
