7800 XT Sapphire Trixx Issues
10 Feb 2022
Westmidlands
Afternoon All
I have been having a few Issues with Trixx. After doing a Google it seems that I'm not the only one to have problems with it. All I'm trying to do is change the colour of the LED. it doesn't matter what I seem to try, it doesn't work. I have installed and reinstalled Tixx and GPU drivers. I have Uninstalled the drivers using DDU and followed a few process that I have read online.
Any ideas?
Erm, you could refresh the operating system. That may work.
Perhaps back-up operating system before you try it, with Disk Genius?
Otherwise, maybe its a hardware issue. And RMA time. Trixx working fine on Windows 10 Pro 64 bit. For me.
What model is it? You can't change the LED colour on the Pure, for example.
The Nitro comes with an ARGB cable that you can plug into the motherboard, maybe you'd have more luck doing it that way.
Its the nitro.
I've just done a full reinstall. Though and behold I downloaded trixx before anything else and it worked. Problem solved, happy days.
Thanks guys.
Just tested with my nitro & changing the led's is working. I've never had an issue with it but tbf I rarely change it. V 9.7.
