7800GS Aftermarket Cooler or Waterblock?
5 Sep 2005
Northern Ireland
Would any be able to tell me what aftermarket air coolers or even awhat waterblocks fit on a 7800GS?
As far as I know the RAM and the HSI will need to be cooled seperately? How would I go about doing this? Just ramsinks and Artic Silver Ceramique?
My 7800GS is at the minute overheating, as the fan on it is a bit dodgy....I got it cheap though, and this seems to be the only problem.
If there is a waterblock, does it have 1/2" ID connectors, or would I need to step the pipe down?
Any advice on cooling a 7800GS better is appreciated, so if you can contribute anything, please chime in! :p
Difficult question. You might have to make custom fittings and go from there. The HSI bridge will need a heatsink aswell. Tough job.
Good luck.
