7800GS coolers ?
  • Thread starter Thread starter Seirrah
  • Start date Start date
Seirrah
Seirrah
Seeing as the Zalman VF700-CU and Thermalright V-1 Ultra don't fit a 7800GS, can anyone recommend any other coolers of this standard?
Noise is an important factor.
Thanks
According to the Zalman website, the VF700 fits a 7800GT, so is the GS different then?
I've just purchased a VF700 for my 6800GS, on the basis that it supports the 6800LE/GT, so hope it's ok!
Well the 7800GS is different.
Regarding the VF900-Cu, "NVIDIA Geforce 7800 Series (except 7800GS) " :(
bumb.
iam thinking of getting a 7800gs as well , and would like to know if there any coolers for it. thought i bump here instead of starting a new thread
I'm afraid that there doesn't seem to be any :( ..and the stock fan is pretty noisey! I'll have to look into adjusting it somehow.
think ill order a Zalman VF900-CU for the 7800gs ive ordered, i know zalman says it doesn't fit, but ill see if it can be moded to fit, and if it can't then ill just fit it to my 6800gt in the second machine, so ive nothing to loose
Or just remove the plastic shield from the heatsink, disable the fan and strap an 7volt 80mm to it with some cable ties!
