- 9 Feb 2006
- Bridgwater/Somerset
Hi all
got a problem with a BFG 7800gs the card works right untill it get into windows then it will only run at 640x480,ive installed the latest bata drivers to see if that would cure the problem but it didn't.
I looked in device manager and it says that theres not enough resources to run the card, if i remove my x-fi card then it run absolutly fine but if i put it back in it has the problem again. i have tried putting the x-fi into a different PCI slot (tried all of the pci slots) yet it still has the problem.
If i put my old sblive card in it works fine.I even tried disabling all unused port e.g coms and some usb still doesn't help at all along with trying to assign irq manually thought the BIOS.My system is overclocked but i have tried setting every thing to stock but it didn't cure the problem
full spec
P4b [email protected]
Abit IS7-E mainboard
BFG 7800gs
Geil value 1GB ram
Soundblaster X-FI FPS edition
Enermax 600watt PSU
any idea what i could try next?
thanks
full spec
BFG 7800gs
Geil value 1GB ram
Enermax 600watt PSU
thanks
