I see, further testing is requiredaardvark said:its very rough - sometimes its too high and you get artifacts in games, sometimes its too low and you can push it a lot more but its a good strting point.
Dutch Guy said:Yesterday I installed my new parts and quickly tested overclocking my XFX 7800GT and auto detect suggested 488Mhz/1.12Ghz
But should I test further or is the auto detect usually spot on?
The memorychips that are used on 7800GT's are rated at 2ms so they run at max speed when at stock, that is why the memory overclocks are modest.aardvark said:i just got a new 7800gt and auto detect is actually pretty close this time - it gave me 490/1.18 and that ran fine.
increased it to 500/1.25 - and i get crashes in need for speed.
i think its the memory and not the core that is stopping me going that high but i'll test further at the weekend.
as a side note i'm surprised how hot the core gets (compared to my 6600gt) - i'm having to run my zalman at full speed to keep it below 60 degrees
If the card is stable when it's under heavy load I'm not bothered that it is going towards 80C, GPU's can take the heat a lot better than CPU's, the thermal threshold temp for a 7800GT is 115Caardvark said:yeah, the noise is irritating, especially as i often leave the pc on overnight - i'll probably get the best core i can out of it using the fan at 12v and then put it down to 7v and see what happens - whether the extra heat makes a real difference or not.
i only put the fan and heatsinks on last night anyway so it will take a day or so for the thermal compound/tape to reach its optimum performance.
