Let me clarify what he just said as I've just spent the last 8 hours learning exactly what you can and can't do with SLi as it relates to multiple monitors.
First of all you CAN run one monitor off each card, as long as you plug the monitors into one card each and disable SLi. You can also run 2 monitors off one card (assuming your 7800gts have 2 output sockets) with SLi disabled, which is what most if not all dual monitor games require. I've been playing Supreme Commander today and there is no choice but to run both monitors from 1 card without SLi enabled. It's a rough ride with only 1 7900gt.
In theory there is no reason you couldn't run up to 4 monitors from a pair of cards, you just wouldn't be able to use SLi. As soon as you do turn it on, you are forced to use 1 monitor.
