starbug said:The GPU's must match, but you can use another manufacturer as long as your using nvidia driver 80 and above (I think)
I've got an XFX 7800GT (the pre overclocked one) and paired that with a OCUK 7800GT at stock speed. You can also mix memory sizes but it's not recommended....
good luck finding another 7800GT card, they're like hens teeth these days![]()
starbug said:although I'm just wondering whether your PSU will be up to the job, I've got virtually identical spec as you but I did upgrade to a 550W psu in case I wanted to go SLI
pastymuncher said:All the 7800GT's i have seen lately have been the best part of £200 which is ridiclous seeing that you can get a 7900gt for around £170.
I think your best bet would be a well known auction site. Quite a few BFG's have been turning up there too.
