7800GTX and 2560x1600 / Dual-link
11 Aug 2004
London
Will the 256MB 7800 GTX work with a 2560x1600 dual-link monitor? like the Apple cinema display or the Dell 3007WFP.
If it does, then how does it physically connect?
The card has two DVI outputs... so would it be possible to have a 2560x1600 dual-link monitor connected plus a 1920x1200 monitor connected aswell?
Cheers
The lower socket on the 7800gtx is daul-link for 2560x1600...You need a daul-link dvi cable if the monitor not come with one..
I see no problem with running a 1920x1200 monitor.Pluged into the top 7800gtx socket at the stay time..
