Tricky one this. Hardware is as follows
Mobo A8V-VM SE
CPU SD 3700
GFX 7800GTX 256
latest and correct bios and drivers for all hardware.
XP fully patched
All are at stock with 2x512 Ram connecting to an Analogue 17" monitor.
Its a new build and all components worked fine in a previous build.
The rig runs fine using the OB graphics, i booted into the Bios with the 7800gtx instaled, i changed the bios gfx setting from OB VGA to PCIE VGA.
I shut down and connected the monotor to the 7800 using a DVI to VGA adapter.
When i boot up the monitor comes on but i get a black screen there is hardrive activity and the fan on the 7800 is spinning but not at full power.
If i boot with the 7800 instaled but using the OB gfx then the 7800 fan runs at full speed.
I cant test the 7800 and adaptor until i get back to work later today (in the rig in spec) and i cant try another PCIE card or another adaptor in this rig until next weekend.
As i cant rule any component out at the moment i see three possibilities.
1 7800gtx broken (all ive done since it was last used is removed the WCing block and refitted the air cooler)
2 DVI-VGA adaptor broken
3 Mobo PCIE slot broken
Does anybody have any suggestions or comments.
Mobo A8V-VM SE
CPU SD 3700
GFX 7800GTX 256
XP fully patched
