7800GTX standard Overclock?
24 Jun 2005
Sussex, UK
I have a standard 7800GTX 256MB... and i was wondering what max overclock do you reckon i could get on AIR, stock is at 430/1200... :confused:
Impossible to say, its hit and miss. But i clocked mine to EE speeds and left it at that (490/1.30). It seems happy enough.
I managed to hit just under EE speeds with mine with the stock cooler. You'll see artifacts and corruption before temps become a "real" issue, so I wouldn't worry... :)
I say set it to 450/1250 and then work up from there..
The core should top out somewhere between 470 to 495 on most..
You should see between 1325 to 1385 max on the memory..
thnx, i did get 470/1250 ... but after installing the new nvidia drivers, it resetted the clocks...
Yes - the overclock is done through drivers...
If you want it to keep the clock settings between driver installs you will need to flash the bios.
at stock 430/1200, my 7800GTX got 7797 3DMark05
and at 490/1300, it got 8728.... does that seem right?
system is in sig... no artifacts or corruption...as far as i can see..
got my leadtek the week the gtx's came out.
it'll clock to 472/1300 on standard cooler.
8,261 '05 marks with a 3700 clawhammer @ 2.75ghz
510/1.37 on my Leadtek using coolbits, coolbits is a little restrictive as i think i could go a fair bit higher.
I removed both the core and mem cooling and replaced the horrid conductive pads with AS5 and the temps at idle are 36-39C depending on room temp (39C atm and im comfy in a tshirt), no sign of artifacts in 3d2005 or COD2.
I may lap the HS as its far from smooth.
nick_cfc said:
490/1350 on mine, runs fine in everything, never had any probs, coolbits wont let me go higher
Was that on auto detect or manually, auto detect gives me slightly less than that and manually it it allowed me 505/1.35.
Thats a fair bit higher than before i replaced the thermal pads.
I can get my POV 7800GTX to 490/1300. It can only go a few MHz more before it gets errors in ATI Tool.
It does get pretty toasty though very near 80C under load but the cooler is stock and extremely quiet. Does anyone think a better cooler would get me a worthwhile increase from my 490/1300?
hmm, i have droppped it to 450/1250 now...
seems to me, shown artifacts in CS: Source, missing graphics and stuff....?
i say about 80%+ can (i can get my POV to) 493/1301 in my small case (stock or AC cooler) leave the window open to let the cold air in it do 510/1390
i used 3dMark05 to benchmark it at 490/1300... and got no artifacts or corruption...
hmm, but in CS:Source, i see blocks of mismatched textures.... anyone else get this?
