7800GTX + Super Lanboy?
1 Dec 2005
Stoke on Trent
Anyone using 7800GTX card in thier super Lanboy? Im not sure they will fit, especially as im using a tagan psu with quite chunky pci-e power connectors.
I know a 7800gt will fit.
And I am sure a 7800gtx will fit, I think I have seen pictures. :p
The case is fully ATX 2.0 compliant so it will most likely fit. :)
I have used a 7800GT in my Lanboy with a modular PSU, it has similar PCI-e connectors to the tagan. It was fairly tight but woked fine by running the PCI-e cable down the back of the HD/Optical bays and then trough the gaps used for IDE cables.
Best (old) pic I have of it:
You can see in the picture there is plenty of room.
It should fit as it is still within the same ATX spec as the Lanboy.
