7800GTX VIVO problem
7 Mar 2005
I get a code 10 error (device cannot start) when installing the Nvidia WDM video capture driver (4.03, latest, with 91.73 Forceware drivers, latest DirectX 9 libraries, Windows XP Pro SP2 operating system). Anyone have any ideas on how to fix this? :confused:
The Error Code 10 means the Windows are able to enumerate the hardware.
if you get a fail CODE-10 then Windows was unable to match the PCI device to any known hardware.
In this case there are only two know causes.
1.) Windows does not have to data to match the device (ie. No drivers installed).
When a device driver for a device is not available, Device Manager displays the device as Unknown Device, and places it in the Other devices branch. This is very common with Universal Serial Bus (USB) and Institute of Electrical and Electronics Engineering (IEEE) 1394 composite devices. Also, a status of Error Code 1 or Error Code 10 may be displayed when you view the properties of the device in Device Manager.
2.) The device is not present or not working properly.
This is a hardware issue.
The hardware issue could be as simple as the board is not seated correctly or the AGP or PCI slot has a problem. The card my be defective or your motherboard may have a problem.
What we do know is Windows was unable to read the PCI device information from the card and match it to what was found when the driver was installed.
