7800x3D build
21 Mar 2012
Been out of the loop for awhile I’m set on the 7800x3D and probably a rtx 4070ti super , could you guys help me with the other components, budget of around £2000
What resolution are you planning on playing at ? Your answer will dictate which GPU is the best fit.
Cheers mate that’s perfect, would I need to flash the bios on that motherboard for the cpu ?
Your welcome.
No it Should be compatible from the first bios but it's best to update the bios because there's lots of fixes,,etc.
There are lots of 4080 supers around that price so have a look.
