- 30 Sep 2023
- United Kingdom
Hi,
I realize its probably something that got discussed here plenty of times but what fan curves are you using for 7800x3d? Just completed my PC build with this CPU and I am noticing some strange temp spikes - example would be when previewing vid on YT temp almost instantly jumps from 37 idle up to 60c. I know this is not a crazy temp for this CPU but it makes my fan speed up quite a bit which is bit annoying...
I am using pearless assassin as a cooler, I don't think I got any issues with temps in general, idle is 37 and cinbench heavy load goes up to around 75.
Is it normal for this CPU to randomly jump by 20c in couple seconds and do you just set your fan curve to actually start after 60c?
