7800X3D or 7900X with a 3070?
If it's mostly for gaming then 7800X3D, if you use heavy productivity applications too then 7900X.
If you're ok dropping a teir the 7700 non X gets close to both and it's cheaper with lower power consumption.
For pure gaming the 7800X3D is the better CPU.
Does your mixed workload make use of the extra cores?
At the moment, I'm not sure. I'm just slightly thinking the 7900x would be a bit for "future proof". But I'm so far out of the loop it's hilarious lol
If you're not doing anything super intensive or dependant on multiple cores the 7800 will be fine. But 7900 will cover more bases with a very minor compromise on gaming.
Pretty much anything. As I said I want to make it as future proof as possible (had the old i5 Haswell for around 10 years). But I guess the main initial use would be for gaming.
If you regularly do long-run multi-core workloads like blender then get the 7900, for anything else get the 7800X3D.
yeah typically if you don't have a specific need for a 7900x you're better off getting a lower model and saving the cash, then in 5-6 years sell it and use the cash to get the latest CPU supporting the socket
The 7900X is actually cheaper than the 7800x3D. Hence my dilemma lol
oh for a 3070 a 7700 would be fine, the 7800x3d is more for pushing hard with a 4080/4090
Agree with this. A 7700 saves you over £100 and will perform 99% as well as the 3D part when mostly GPU bound (which most of us are). Once the 7700 is struggling, you'll be £100 further towards your next upgrade.
I've played the budget option myself, upgrading from an i7-4790k to a 7600 and the jump was huge! I was tempted by the 7800X3D but that £200 difference means I can jump on the next low-mid range refresh sooner, or prepare for wallet rape in the GPU market.
