Hi Guys,
It seems I have been having this problem for a while with planetside 2 where the game will randomly lock, sometimes it will play for hours, other times it will be a short period, and sometimes not at all.
I have kind of put up with it, but I just got Titanfall, played it three hours last night no problem, played for about 1 hour today and it locks up, then 30 mins it locks up.
Each time my PC totally freezes, and I have to do a hard reset. I thought the PS2 issues was with the poor coding as other people have had it too, but with it now happening on titanfall too, I am now thinking it really is an issue with my machine.
The machine is only about 6 months old, spec is:
MSI Z87 G45 mobo
16GB Ripjaw 2133mhz ram
4770k currently running stock boost clock of 4ghz
2x Zotac GTX780's in SLI running Nvidia surround
CM liquid cooler
The errors I have seen are bellow:
Display driver nvlddmkm stopped responding and has successfully recovered.
This was one of the first lockups today where I managed to ctrl+delete and then it said titanfall.exe has stopped responding.
On the subsequent two lockups:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
CMDre 00000000 00000454 01200000 00000004 00000010
I have done a clean driver install of the latest Nvidia drivers.
My top GPU hits 79 degrees and throttles very slightly as I have it set at 79.
My lower GPU is normally around 60.
If anyone has any ideas on what to do to try and troubleshoot this it would be much appreciated.
Cheers!
MSI Z87 G45 mobo
CM liquid cooler
\Device\Video3
Cheers!
