- 12 Jan 2009
I have an EVGA 780i SLI mobo and a new Coolermater 850W Silent Pro PSU.
I installed a GTX 295 and the PSU at the same time, and have had sort of GPU issues (in other threads), kernal driver not responding etc.
The motherboards 8 pin socket is configured (mobo orientation with 8-pin in top left corner), is:
(clip)
[ A S S A ]
[ S A A S ]
(the shape of the pins (square and arched))
The PSU, however, has 2 lots of 8-pin ATX cables (permanently connected to the modula PSU), configured as...
(clip)
[ A A | S A ]
[ A A | A S ]
(2 lots of 4 pins)
(positioned to line up ready to plug into socket and clipped)
so, how am I supposed to plug in the 8-pin ATX?
Meanwhile I have been using a MOLEX to 8-pin adapter cable, but have been having GPU issues (screen blanking and kernel driver not responding), but I put this down to a GPU problem... as nobody really had a clue.
The GPU problem was a pain, so I took out the GTX 295 ready to send to my son to test in his PC and put my old 8800 GTS in. All fine.
This morning, after a few days with the GTS in, I turn on PC, and it does not post, just sits there with HDD led on, no screen, then powers herself off after 30 seconds.
I remove case to find the mobo LED showing "FF" which appears as soon as you turn on PC, and a red LED near the CPU fan socket.
Done some googling, and found that it could be CPU overheating, or not sitting properly etc - but I have not touched the CPU. I then found someone had tried a different PSU, and his PC was all better...
So, I plugged in my old Enermax 500W and the PC boots fine. Plug in the new Coolermaster, and problems again...
So, do I have a general PSU problem, or is using the MOLEX adapter for the 8-pin ATX causing an issue....?
Why does the Coolermaster 8-pin not fit into my mobo ??
Any help will be muchly appreciated...
Demon
(clip)
[ A S S A ]
[ S A A S ]
(clip)
[ A A | S A ]
[ A A | A S ]
(2 lots of 4 pins)
Demon
