780T Vertical GPU Bracket
I suppose you can't get anything custom as well.
I looked into this as some point I am going to customise my case and use a riser to display front of card. The only thing I can find I can't link and would mean cutting rear of case and I'm not sure how suitable yours would be. Try googling for 'pci io bracket'. As I said it would not be an easy option and might not suit your case and would need extra support
Not sure if that would work,
I think Cooler Master are the only ones who do this but didn't like the design of any of their cases.
Looks OK going to have to have to get my next case with a vertical bracket although not a deal breaker
Didn't realise a thread had already been started, I love the whole tempered glass thing but after reading through that thread it is a very dated design really.
also has anyone any experience with this :
Thermaltake PCI-E x16 Riser Card Cable Black
Found it on the forest
