780Ti ROG Matrix noisy fan
24 Aug 2006
Cardiff
Recently bought an Asus GeForce GTX 780Ti ROG Matrix from OC and whilst i'm very happy with the performance of the card it has a noisy fan specifically the one nearest the DVI ports etc. If I touch the centre of the fan lightly it will go away for a while and then return, its rather annoying as I like to fun as quiet a rig as possible.
Has anyone else had this issue with the card? Is there a quick fix for this that anyone could recommend? Do I really have to RMA the card for this small but nevertheless annoying problem?
:confused: :(
