7850 arrived.. Not same as pic (not ocuk)
Caporegime
13 Jan 2010
Llaneirwg
Have been looking for a reference 7850 for a while now and thought I had found one. Card arrives and it is a sapphire dual x version.
Looks like there might not be many about.
I'm guessing most people don't want reference but I really can't have heat being blown into my case
Anyone know of any?
That one also throws the heat out the sides though as it's not covered!
It sucks air in from top bottom and sides and then pushes the air out the back of the card(back of pc) you may get a small amount of leakage from the sides but its the best solution for your needs massively better than stock cooling with the addition of pushing the hot air out if the case.
I'm sure someone with his ice q will comment on here and they should be able to tell you if there is much air that comes out the sides I can't comment on this as I run a 7950 wf3.
Yeah its a Htpc case and not good with cooling really especially getting the air out.
It'sa shame that iceq seems so expensive, 60 more than the sapphire, the cooler should fit. Just.
I will try the card, it's short which helps a lot.
looks like the gpu is 15C cooler on idle than the 6950, yet to seal it up (both tested with no lid at this point)
