7850k overkill?
30 May 2007
Glasgow, Scotland
Hello!
I currently have an htpc, and 7850k... It is purely a media centre.
I think its over kill, so thinking about a change... Would also like to quieten it down some!
Oh and I Aldo like tinkering, so that justifies the change :p
How is the intel HD 2500 found on the i3 3220? Or should I aim for haswell i3... Or will pentium suffice!
Thanks guys!
What is the point your going to end up losing money and have inferior performance surely?
To be fair, the OP does mention about making the PC quieter.
craig_kennedy83,
You really don't need that much processing power to play media files on to a TV. Have a look at some of the NUCs and even the Android MX boxes. So yes, you could quite easily downgrade and get passive cooling to make things silent.
Buy quieter fans?
Limit the speed of the fans?
Undervolt the CPU?
Plenty of options available without needing to tear the system apart and spend money on a new CPU and mobo.
Now that you have one keep it. I would only change if you were upgrading.
Kinda want inferior performance, that's almost the point.
craig_kennedy83,
Thanks! Ooo NUC's look interesting, if not expensive for what they are.
Buy quieter fans?
Undervolt the CPU?
Fan is on silent, it's an Arctic Cooling something or other. Only other fan is the PSU, perhaps that is where the noise is coming from. Oh I do have 1 mechanical drive in it for media, most runs from the SSD.
My last motherboard, I'm sure, had settings to turn off cpu cores. From what I can see this one does not! Fortunately I stumbled across TDP, which I have now set to 45 rather than 95.
Perhaps I could go all passive, PSU and CPU.
It does everything you need it to?
Unless this is something to do with money... then just de-clock or get a better cooler to get quieter, and yes... the PSU can definitely be making noise.
Hello!
Tinkering + media centre = Raspberry pi 2
For the price its very good & you can use it for other PC projects too. At least buy one for school IT homework if you have teenage kids. For the record it makes no noise at all! :p;):D
