7900 XTX Reference PCB
18 Nov 2019
Afternoon everyone,
I am looking to use a EK Vector2 Black GPU waterblock but it's only compatible with the reference AMD 7900 XTX PCB. It appears that Sapphire, PowerColor and even Asus produce cards with the Reference PCB but I wondered if anyone knew which one for sure? Didn't want to spend 1K on a GPU, take it to bits and then find I can't fit the block.
Cheers in advance
The MBA cooler is very recognisable and usually the card has a shorter warranty too.
The description of the product will NOT have a custom model in the name, for example: Pulse, Fighter or Dual are all custom cards that are not what you want.
