7900gre on 7800x3d?
23 Oct 2002
Liverpool
Hey guys. Currently have a 5800x3d with a 7900gre. But have the upgrade itch, anyone using the GRE with 7800x3d system?
How does it do? Mostly use my rig for msfs 2020 or P3d.
What resolution are you playing with. From the tests I’ve seen the higher the res the more likely you will be GPU bound and not see much difference
