A friend of mine has just bought a BFG 7900gt PCI-E.
Unfortunately I’m not sure if his PSU is compatible... Do PCIE cards require PCIE compatible PSUs??
Or am I correct in assuming that you can use a converter to go from a couple of standard 4 pin Molex’s to a 6 pin PCIE:
Included in box - Dual 4-pin to single 6-pin power cable
(From BFG website (http://www.bfgtech.com/7900GT_256_PCIX.html))
Any help is much appreciated,
Thanks
Thanks
