Hey guys
I've having problems with a system I built recently. Core spec as follows
ASUS P5W DH Deluxe Motherboard
Core2Duo E6600 CPU
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Hiper HPU-4M580 Type R PSU
And of course, an MSI 7900GTO graphics card.
When I built the system it booted fine and I began installing software, however when it got round to it's first reboot that was it, no video output. The system beeped with 1 long beep and 3 short - no graphics card. Further reboots did not resolve the problem.
The next day after leaving the system powered off at the plug all night boot up was successful. The first thing I did at this stage was to upgrade the BIOS. Everything looked as if it was OK for a while and I get an OS installed, then suddenly while browsing the system reboots. On boot again there is no video output and it beeps as before. Reboot doesn't resolve.
The following day was a Saturday, again it boots OK after a night powered off and I actually managed to get some gaming in with no problems, however after heading out and leaving system idle for a time I come back to find blanks screens yet again.
SHould point out that when this happens and there is no video output the system is working fine. I can get access via remote desktop and everything is ok (and very fast)
So, I described the problem to OCUK and they initiated an RMA on the GTO. Before I sent it back I managed to get it tested in a system in work which worked... for about 20 minutes, then the usual no video output. The only difference was reboot seemed to solve the problem.
I went away with work for a week, come back and there's a GTO waiting for me. There is no note or anything in the box so I assume it's a straight replacement. I run home eagerly to get gaming however when I open the now very damaged box the contents look overly familiar, it's the same card back... I try installing it anyway, maybe they have flashed it or fixed a loose connection but no, still the same
So, we get to now. I have tested the card in a friends system with the same results and I have tested 2 other cards in my system with absolutely no problems. I am not getting any response from the support staff and I'm totally out of ideas.
Please can somebody give me some suggestions as to what I can try next?
Thanks
Core2Duo E6600 CPU
Thanks
, 9700NP, 9800PRO, 6800NU, X800XT)
