- 24 Feb 2007
hi this is more for a friend than for me but just a quick question. He has 2 vga monitors and is trying to get dual display using 1 of those dvi>vga adapters. Ive seen somewhere (cant remember where) that there might be a problem using dual display with those adapters can anyone clarify? basically his problem is that the second monitor never displays when plugged in e.g you put either monitor in either port first and it will work fine, 2nd 1 gets no display. Obviously we checked drivers etc infact hes even had the card replaced to make sure its not that. Since both monitors and both adapters do work im thinking it might be a compatibility issues, any thoughts?
