7900GTX n HD
Permabanned
2 Nov 2005
stockport, cheshire
OKOKOK,
i am back to using my SINGLE!!! (yes i know its a shame but the other died) BFG 7900GTX. I am using one ViewSonic as prim screen but i bought a new 32" HDTV last nyt, i wanna use it in HD from ma PC but....
has anyone done this on the same card? i set it all up nps but then it said about if its not the reet screen it will break the ViewSonic basicly, i am not sure if it will, just dont wanna chance it.
QUESTION... Finaly. Wil it break the viewsonic if it does put it on HD?
Which DVI is the HD output on the card?
And when i go through the screen setup (NIZ) i can select the primary display then select HD.
