7900GTX SLI Detecting wrong speeds
5 Jul 2006
Ive installed Coolbits on my computer, went to the clock settings and the speeds showed 400/800 :confused:
Anyone know why its doing this and how i fix it?
thanks
If you go into the option to change the frequencies (been along time since i've used this so can't remember exact thingys) and change that to 3D. (if ofc it is only showing 2D)
Stock GTX will show 800 for the memory (1600 effective due to DDR2), this is a quirk of how 7900 series frequencies are displayed.
