- 13 Sep 2010
Hi all,
I've recently upgraded from a 3060ti to a 7900xt Pulse and have been having some issues with display signal to my 4k TV over HDMI.
With the 3060ti I had it running from the HDMI port to my AV receiver (via 5m HDMI cable rated at 18gbps) and then out of the receiver to my TV via the ARC HDMI port. (never had issues with this set up!)
When I initially installed the 7900XT, I was having some pretty major issues with the sound cutting out, especially when the tab playing sound was not in focus.
I ordered a higher rated HDMI cable (5m, 48gbps), but this did not improve things.
I then put the HDMI from the card directly in to the TV, with sound then running to the receiver from the TV via ARC, this has fixed the sound dropping out, however I have noticed that I'm still getting very minor and infrequent issues with the picture;
Occasionally I am getting a thin black corrupted bar appearing on screen, only for a fraction of a second and often going for several hours (or even days) without it happening (or me noticing it), but other times happening multiple times in an hour.
When I first mentioned this in the Sapphire deals thread, a few people said that AMD cards are just more fussy than nvidia with cable quality and I appreciate that 5m is a bit of a long run for HDMI, however as I watch most content via PC on the TV it's not a great situation.
I would love to find a solution to this as I'm otherwise very happy with the card (performance, noise, coil whine etc.) and may have trouble returning it as I have redeemed the Starfield code to my AMD rewards account.
I don't have another 4k display to test, so far I have not noticed the issue while gaming/under load, so was wondering if it was maybe similar to the issues that used to be present with multiple/high refresh screens at idle clocks.
The only other things I can think to try are either a DP to HDMI adapter, or a fibre based HDMI cable, but I'm unsure if these are likely to be any better.....Any indication would be much appreciated!
Thanks
Thanks
