7950 Overclocking problem
9 Mar 2008
Glasgow
Straight to the point, whenever I touch the voltage (at all) my game instantly crashes and get a message ''amd display driver has stopped working and recovered''. This only started happening when I put the card in my new build (before I could clock the hell out of it and it didnt mind). Temps dont seem to be an issue, I have the problem on both bios switches, and similar to voltage, if I clock the memory or GPU clock beyond, say, 1000Mhz core and 1250Mhz memory it crashes aswell. I would just leave and settle with that being the limit, but as said it was running way beyond this before I put my new PC together so was wondering if anyone can suggest something I may of missed? I have had two complete fresh installs of Windows and still get this issue and used several different driver versions, again all with same problem.
Spec:
Saphire 7950 OC edition
Asus Z77 Sabertooth
Intel Core i5 3570k (OC to 4.3Ghz)
Corsair 1000W
16GB DDR3 memory
Samsung 830 256GB SSD
(dont think the rest matters)
