7950 rebooting system - need urgent help!
5 Sep 2009
God's own country
Hi all, I've got a HIS 7950 IceQ Boost Clock 3GB (http://www.hisdigital.com/un/product2-725.shtml) and I've just installed it on a fresh Windows install. It works perfectly fine for mundane desktop tasks, but the second I load up any game the system will reboot without warning.
Had this problem with Win 7 and am now having the exact same problem n Win 10 64-bit.
I'm only guessing it's something to do with the boost feature, but any help much appreciated.
I really need to get this sorted before Monday as I'm going to be laid up for a long time from then. :(
I have tested the RAM and the PSU is perfectly happy running a GTX580 (GTX580 atm).
HELP!
sounds like a driver issue... the latest AMD drivers are crashing systems, we all know that... try the older drivers and you should be ok
