7950Gt or x1900xtx
23 Oct 2002
Norwich
just seen a x1900xtx for sale [edit] in the for sale forum, or the new 7950GT
quick reply would be nice!
thanks
Well ive just been looking at a review, and the x1900 XT is better in that.
Unfortunately i cant link to it as its got some competitors on, but the x1900 XT is about 5 or so frames faster in games with AA/AF, so the XTX will be a few more id have thought, if you want less power used , less heat given out then go for the 7950 GT, but if that doesn't concern you, and you fancy the AA+HDR that the x1900's can do together, and the less performance hit when using AA, and the better IQ then go for the x1900 XTX, or just get the cheaper XT and clock it to XTX speeds which it will do without farting as the XTX's clocks are not that much higher. :)
Why delete it?
I found it quite helpful so I'm sure it will help someone else out...
