Well so far, some gains at least:
Removed 12.4, once removed I ran driversweeper, then installed RC11 (25th Jan). Also realised I had both unigine 2.5 and 3.0 installed, removed both, reboot, reinstall of 3.0. Checking for hidden display adaptors didn't show anything btw.
Benched so far with the following results, all with Power at +20%, stock voltage is 1.112v, getting vdroop down from 1.2v to around 1170mv :
Heaven 3.0
1050/1325 - Stock volts, ccc OC, no artifacts
1100/1325 - Stock volts, ccc OC, no artifacts
1105/1325 - Stock volts, ccc OC - artifacting from early on ~stage 10+
925/1500 - Stock volts, ccc OC - no artifacts
925/1325 - 1.2v, AB no OC - no artifacts
1100/1325 - 1.2v, AB OC - no artifacts
1105/1325 - 1.2v, AB OC - no artifacts
1110/1325 - 1.2v, AB OC - artifacting on stage 21 of 26 onwards.
1100/1450 - 1.2v AB OC - no artifacts
1100/1500 - 1.2v, AB OC - no artifacts
Kombuster
1105/1500 - 1.2v, AB OC - no artifacts
1125/1575 - 1.2v, AB OC (ccc limits) - no artifacts, would almost instantly artifact on 12.3 & 4
Some definite improvements, still struggling to hit those CCC limits under heaven but its progress, I have to say my case probably isn't helping matters, the 800D is a stinker for air cooling.
I am now noticing some strange happenings in windows, purple line flashing across the width of the screen, I hear this may be down to ULPS kicking in though?
When I get home tomorrow I'm going to leave heaven running at stock speeds for an hour or two and see how everything is to double check the cards stock stability.
