Hello All,
I have a problem with my current rig.
I have a coolermaster 850 PSU and two Gigabyte 7970s
First off, the first 7970 had a defective fan which lead it to overheat when i first installed it - OCUK fixed the fan for me and i've been using it in a crossfire ever since.
When I play games like BF3 after approximately 30minutes my pc reboots, when it reboots the bottom card (the one which was previously broken) fan goes to 100% for about 20 seconds as if the fan is remembering it overheated, the top card (they are an inch apart) which runs 15 degrees hotter does not exhibit the same behaviour, the fan stays at 20%
If i disconnect the 2nd card, and run heaven 2.5 for an hour, my top card stays at 75 degrees but my pc does not randomly reboot, if i use the 2nd card, or use both cards in crossfire my pc reboots.
Basically ive pretty much had enough of this, and im going to drive to OCUK tomorrow to request a refund on my card, but i have a question.
Do i have to wait for them to test the card themselves to see if it crashes on their rig, or as its only 20 days old and I ordered over the net can i simply say im dissatisfied with the purchase and not have to wait around for a refund
this is simply a case of 'which is quickest'
many thanks
many thanks
