7970 Fan speed 100% when computer idle
bbK
bbK
12 Dec 2003
wales
Doing my head in as I have no idea what's causing this... I've googled it and found that other people are having this issue with similar cards but I haven't been able to resolve it so thought I would ask here.
Any ideas much appreciated.
this card
sounds simple but try loading defaults in ccc/performance/amd overdrive
Defaults loaded - same thing.
Have you tried using msi afterburner to adjust it or to check if its on default settings?
Haven't tried that but the thing is if the pc is idle and the fans are spinning at 100% all I need to do is move the mouse and the fans will instantly go back to normal.
