7990 Outputs
The price isn't bad thinking about it, only £70 more then the two 7970's it's based on.
Fairly sure you won't fit a 3 slot card in a prodigy, though putting a waterblock on it and shaving the I/o plate should work :)
I was planning on Water cooling it, Unfortunately there are no blocks out for it at the moment.
Also would need an IO plate made for 2 slots :/
There is a block for the above card, ocuk stock it :)
As for the plate, be easier just to butcher the provided plate, or get a spare and cut that.
I just noticed in the Blocks blerb that it comes with a 2 slot Io plate with the block! BARGIN!
I will order a 7990 and block in April as i get my last every student loan payment :P
Thanks peeps!
the 7970 is starting to show its age in the newest game that are out, thus the 7990 is the only choice considering im on M-ITX
